Air filter...thing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2007, 03:49 PM   #1 (permalink)
View sharifjomaa's Photo Gallery
Air filter...thing
So I asked this question in another thread but no one replied. I replaced my stock filter with a short ram intake..anyway about an inch from the new filter there's this black hollow plastic pipe thing that looks like it's in about 2 or 3 pieces or so and goes down under the battery and comes up around next to the battery..I don't know if that makes sense..anyway do I still need those plastic pieces or can I remove them?
sharifjomaa is offline   Reply With Quote
Old 09-09-2007, 03:58 PM   #2 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
ii suggest you keep it, you will want to use the original assembly and air filter for the winter
Rookie_One is offline   Reply With Quote
Old 09-09-2007, 04:01 PM   #3 (permalink)
Really? What's wrong with a short ram intake in the winter?
Old 09-09-2007, 04:17 PM   #4 (permalink)
Rookie_One's Avatar
air entering the engine too cold when the engine is not enough hot, in fact a friend of mine had problem with his car (engine hesitating until it was hot mostly) and when he reinstalled the original, the problem disappeared
Old 09-09-2007, 09:58 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I've never had any problems with air being "too cold" when it enters the intake.
sharif, post pics.
Old 09-09-2007, 10:13 PM   #6 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
You don't need to put things back in the winter. Colder air is better, period.
All that....STUFF....is just intake plumbing. What you see under the short ram filter is actually connected to the air inlet under your bumper--it's by default a cold air intake, although the way it's designed incorporates tons of bends, diameter restrictions, and silencing. Aim it at your filter and you'll get the benefit of air from the colder location as well as the low restriction of the SRI. IF you're feeling adventurous, you can take out your battery and go hunting for all the plumbing and tape off or remove anything that doesn't lead straight to that little upturned triangular bit. If you're feeling more adventurous, you can put the car up on jackstands, unbolt the wheelwell plastic cover, and get to the intake location, put the filter there, and figure out how to run a pipe from there to your TB..and presto, home-made CAI.
WIP AE102.
Piloter is offline   Reply With Quote
Old 09-09-2007, 10:14 PM   #7 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Same
sharif, post pics.
Same here....
FinalGear is offline   Reply With Quote
Old 09-09-2007, 10:47 PM   #8 (permalink)
Rookie_One's Avatar
thats depend where too, here where i live its just too damn cold during the winter (-40 celsius someone?)
Old 09-10-2007, 06:26 AM   #9 (permalink)
Well it gets pretty damn cold here too..Piloter, actually by luck that last bendy triangular plastic part is aimed directly an inch or so from my new filter, so that turned out pretty good.
Old 09-10-2007, 07:23 AM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
-40C... umm... thats a finnish summer.
Not possible, only problem is with a carb that the carb stars freezing up, but that happens mostly during only few -C. -40C air is very dry. I never had any problems during winter with sidedraft carbs and I guarantee the air was freezing when it went into the engine.
Only problem was that I had no choke on my car, so I'd have to pump the gas few times then crank and when it started baby it a bit.
Old 09-10-2007, 06:31 PM   #11 (permalink)
7th Gen Apprentice
View costadragon220's Photo Gallery
You're my hero Piloter...
BTW- know of actual instructions,tools and items needed for the battery transfer?.. I need room for future turbo installation
costadragon220 is offline   Reply With Quote
Broken part behind air filter tray cam01speak Camry & Solara Lounge 7 04-23-2007 06:16 PM
Turbo the tercel? Flymasta K Tercel, Paseo, Starlet, and Sera Forum 19 01-30-2005 11:38 PM
Air filter usage ctrigger Archived Corolla threads 0 10-30-2004 11:49 PM
K&N Air Filter _RPM_ Camry & Solara Lounge 23 10-23-2002 09:12 AM
