1zzfe Fuel Pressure Regulator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2007, 08:21 PM   #1 (permalink)
ae924afdx's Avatar
View ae924afdx's Photo Gallery
I am installing a 1zzfe in without using the stock Fuel pump assembly that comes with the FPR {fuel pressure regulator}. I have an msd in line fuel pump that is capable of suplying the 45psi needed for the 1zzfe .
I wanted to know since the 1zzfe doesnt have a return hole in the fuel rail if i can install an aftermarket FPR before the fuel pressure rail?
Have anyone seen a mod like this one done with a 1zzfe?
Any ideas or suggestions?
Thanks.
ae924afdx is offline   Reply With Quote
Old 09-21-2007, 10:45 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You cant, because theres no return line to the tank.
Old 09-21-2007, 02:53 PM   #3 (permalink)
ae924afdx's Avatar
yes .. on my ae92.. that where the 1zzfe is going.
Old 09-21-2007, 03:42 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Why didnt you say that on your first post.
Then its just a matter of getting a fpr that connects between fuel hoses, however I dont remember if the 1ZZ-FE rail has two hoses, because you need to put it on the return side of the fuel system. if it doesnt, then just get a fuel rail made
Old 09-22-2007, 09:33 AM   #5 (permalink)
ae924afdx's Avatar
i found the answer on this website... just like i tought put the fpr before the fuelrail hose. and give it 45psi stable at all times. Weird system but thats how the new toyotas work. from the fuel tank i am going to use first:
. in line fuelscreen {strainer} , external fuel pump, fuel filter, {all of this near the tank..}
Then by the engine bay: FPR .
That shoudl take care of it hopefully.
thanks for the help. And of course i am going to replace the fuel hose with fuelinjection high pressure grade hoses.
1MZ-FE fuel pump pressure hksboost Camry & Solara Lounge 21 12-13-2010 03:54 PM
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
GM to launch world's largest fuel cell fleet in '07 dsmnick General Discussion 1 09-17-2006 02:54 PM
TRD fuel pressure regulator! EKam General Discussion 8 10-25-2001 09:17 AM
