1zz-fe massive oil usage - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2007, 09:28 PM   #31 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
Originally Posted by 94_Rolla_Guy View Post
-If it was 3 liters low it only takes 4-4.5liters i have noticed severe oil pressure problems when only 1 liter low i would assume your lower end bearings are screwed due to air entrapment and oil starvation
-i dont think there is any way bad valve guides could cause this kinda oil consumption(1liter / 500km)
-Im a member of the BITOG forum and have tried some of there snake oil fixes i will sumerize
-Diesel fuel in Oil = no change in consumption, no cleaning help
-ATF in Oil= no change in consumption, no cleaning help
-Diesel Oil (meant for diesel engine) heavy weight slowed oil buring but detergents didn't do anything
-Heavier weight oils ie 20w 50 = This works to slow the burning but will not fix anything...
-Your definately looking at rings in my opinion!
-Be careful buying a used engine bad rings is a fairly common problem on 98-99's
-I would take a hard listen if you have any lower end knocking if so i would be really careful because knocking obviously will kill the engine really fast and could get you in a accident
-Compression tests will actually read high but.. usually youd see a fair difference between a dry compression test and a wet compression test you wont see this because theres already oil present in the compression rings to assist sealing
-Leak down is similar the oil in the compression rings help seal the ring pack, leak downs are more meant to track down valve problems
it wont hurt to try the snakeoil fixes while he saves a little more money. a can of seafoam is what? $8? some oil and filter is like $20? $30 might slow his oil burning a little and if not its a drop in the bucket next to what the real fix will cost.
Old 10-05-2007, 09:29 PM   #32 (permalink)
joeyicu's Avatar
View joeyicu's Photo Gallery
Originally Posted by knarf View Post
Does this mean every 98/99 1zzfe is doomed to this defect? In other words if I buy a used 98/99 1zzfe motor, it will have bad rings? If not, how do I tell the good one from the defective one?
Frank
to tell you the trueth man i think you will probably be able to save money by pulling the motor you have and doing a light rebuild, as in honing the cylinders, installing new main bearings, and any other wear item bears that seem to have defects, im thinking a used motor with decent milede will run you around a grand, but redoing your motor will run you in the neighbor hood of 600-800, and you would be in a better position anyways, since you know your stuffs new
-<2001 Chevrolet 2500HD 6.6L 5A 4x4>- 14.6@88mph - Edge Juice Chip, Cut Muffler
-<1990 Nissan 300zx NA 5M 2+0>-
Stillen Catback, Kenwood HU
joeyicu is offline   Reply With Quote
7AFE oil-burning knowledge pool Piloter 7th Generation (1993-1997) 13 02-29-2012 08:35 PM
1zzfe celica VS 1zz fe corolla Crowbar911 Archived Corolla threads 11 08-07-2011 10:54 PM
2.7L oil capacity incorrect gonesurfing 2nd Generation (2005+) 34 02-11-2011 12:09 PM
1zz fe VS 2zz fe Crowbar911 Archived Corolla threads 4 04-07-2010 10:56 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
