Tapets noisy - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2007, 08:50 AM   #16 (permalink)
View mcgavin's Photo Gallery
Thanks for the help guys. i took the head cover off yesterday. saw the shims.
By luck, managed to get another complete engine that has done half the mileage for next to nothing. am thinking of using that head instead. maybe it will be less noisy with the less mileage it has done.
I am also doing a compression test on the 4 cylinders this weekend, because the car setup is correct but the power on the dyno is quite low. Does anybody know what kind of compression i should be hoping to see for the RSI 20v?
mcgavin is offline   Reply With Quote
Old 10-04-2007, 03:44 PM   #17 (permalink)
The TN Member
View punter's Photo Gallery
Lifters? Rockers?
Ha, people on this site are so helpful .
If it's definatly coming from the head, What you are hearing is the VVT pulley, they wear out and start ticking.
It not a problem really, they still operate normally just tick at low revs.
It could also be bottom end noise (like one of my 20v's )
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 10-04-2007, 03:46 PM   #18 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
More like ignorant, probably never taken the valve covers off and just stating what they heard somewhere.
I was asking about bottom end because usually when you rev, the bearing problems on the bottom end stop.
Old 10-04-2007, 06:29 PM   #19 (permalink)
The TN Member
Usually, mine still does but I doubt it will last mush longer.
Pretty much the only way to run bearings on a silvertop is to starve it of oil, so if that hasn't happened it'll be the VVT pulley.
Old 10-08-2007, 06:31 AM   #20 (permalink)
Old 10-08-2007, 04:30 PM   #21 (permalink)
The TN Member
Should see between 205 - 210 psi.
Although I have a cheap gauge so that might not be accurate.
As long as they are all within 5% of each other the actual number doesn't mater.
Old 10-09-2007, 02:24 AM   #22 (permalink)
Great. Thanks for all the help.
Found solution for noisy leaf springs!!! SOTXYOTA 2nd Generation (2005+) 13 11-17-2006 10:22 PM
7MGTE noisy cams quapouh Supra Forum 5 11-22-2005 09:13 AM
is your car noisy? fungke Camry & Solara Lounge 4 11-17-2005 10:16 AM
Shocks/struts noisy Andrewski Camry & Solara Lounge 2 09-19-2004 02:55 PM
Are 1999 Corollas noisy? hdsalinas Archived Corolla threads 6 01-05-2004 09:46 AM
