Tapets noisy - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2007, 06:28 AM   #1 (permalink)
View mcgavin's Photo Gallery
Tapets noisy
Hi all,
1.6 corolla RSI 20V
quick question, my lifters / tapets are making a noise at low revs. tick tick ticking sound. I am told you cannot stop this as they are auto adjusting. Is this true? I dont see that it can be because they give the valve clearance setting in the users manual?
Thanks
mcgavin is offline   Reply With Quote
Old 10-01-2007, 11:37 AM   #2 (permalink)
Glockaholic...
kn38ms's Avatar
View kn38ms's Photo Gallery
I have an 04' with the 1.8L (purchased new) 79K miles
Mobile 1 oil changes. Sometimes my lifters sound diesel like.
Took it to 2 dealers. Both said its normal.
If I still have this car @100K miles i will have the lifters adjusted.
Hope that helps.
kn38ms is offline   Reply With Quote
Old 10-01-2007, 12:45 PM   #3 (permalink)
Thanks, that does help, but to confirm, you are saying that the lifters can actually be adjusted then? Contrary to what some people have told me? Is the procedure using a feeler gauge?
Old 10-01-2007, 02:25 PM   #4 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
yep, feeler guage, flat head, and I belive a 10mm wrench
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 10-01-2007, 02:40 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
What lifters... there are no adjustable lifters in a 20V. You adjust them by shimming the buckets.
Old 10-01-2007, 02:42 PM   #6 (permalink)
All-Trac Guru
Flashmn can you elaberate on what "shimming the buckets" is?
Old 10-01-2007, 02:53 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Theres shim disks either on top of the bucket (most cases like this) or underneath (usually built in, vitz/echo/yaris) Now you check the clearance with the feeler gauge and then install a shim thats gives you the correct clearance, either buy replacing the shim ontop of the valve bucket or replacing the whole bucket.
Old 10-01-2007, 03:06 PM   #8 (permalink)
Oh dear, i was worried it would be like that. that is hydraulic lifters right?
Lets say i check the clearance and one of them is out. how would i go about getting the correct shim to correct the valve clearance measurement.
Just another quick question - why do these lifters/tapets/whatever you call them become noisy if they are adjusted by oil pressure (they are adjusted by oil pressure right?)
Old 10-01-2007, 04:24 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Nope, they dont have hydraulic lifters.
They are not adjusted by oil.
If one of them is out of spec, then you just take the measurement and then measure the old one and get a new one with the combined measurement. Oh and btw are you sure its valve tick?
Old 10-02-2007, 07:20 AM   #10 (permalink)
good question. i cant say that i am certain. the ticking sound is there until about 2500rpm and then disappears at higher revs. thats all i can really tell you that im certain of.
Old 10-02-2007, 07:32 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
and you're sure it comes from the head not the block?
Old 10-02-2007, 10:52 AM   #12 (permalink)
yeah that im pretty sure of. the car has a branch which in my experience does make it bit louder (had golf with branch before and it became pretty noisy), but i would really like to fix it cos it is driving me bananas
Old 10-02-2007, 02:17 PM   #13 (permalink)
Resident asshole
Flashmn's Avatar
branch? :P
Old 10-02-2007, 02:31 PM   #14 (permalink)
Glockaholic...
kn38ms's Avatar
You may want to remove your oil filler cap to inspect to see if there is a plate beneath
the hole (where a funnel could rest)under the valve cover to see if it is making contact with a rocker arm.
Old 10-02-2007, 03:30 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
^ umm. there are NO ROCKER ARMS IN GE'S...
If you read the posts above you would of seen that I said that already.
Found solution for noisy leaf springs!!! SOTXYOTA 2nd Generation (2005+) 13 11-17-2006 11:22 PM
7MGTE noisy cams quapouh Supra Forum 5 11-22-2005 10:13 AM
is your car noisy? fungke Camry & Solara Lounge 4 11-17-2005 11:16 AM
Shocks/struts noisy Andrewski Camry & Solara Lounge 2 09-19-2004 03:55 PM
Are 1999 Corollas noisy? hdsalinas Archived Corolla threads 6 01-05-2004 10:46 AM
