Has anyone had this ignition problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2003, 01:57 AM   #1 (permalink)
008
View 008's Photo Gallery
Engine starts when cold
Then dies when warm (5 - 10 min)
Then has a no spark condition until the engine is cold again?
Or maybe its my test for spark when it doesn't start.
I have a friend crank the engine as I take a spark plug wire and place a screwdriver inside it, then try to look for sparks holding it near the engine block. I also did this with the wire coming from the ignitor to the distributor. Is this a proper way or is there a better way?
Also, not knowing how the 4age electric system works, can the ECU or some physical heat sensor sense high temperatures and not spark the engine?
008 is offline   Reply With Quote
Old 09-03-2003, 08:35 AM   #2 (permalink)
cosmicbutthairs's Avatar
View cosmicbutthairs's Photo Gallery
Re: Has anyone had this ignition problem?
Its the distributor and or ignition coil or circuit. I had a similar problem. Do a diagnosis check just to double check.
cosmicbutthairs is offline   Reply With Quote
