as spud said, the wiring is there.
the only "tricky" part is moving your odometer to the new cluster. You take the front bezel off and unscrew the speedo unit from the back (there's 6 or 7 screws). the speedo unit contains the odometer. Do the same on the other cluster and switch the speedo units.
you also MIGHT need to switch some wires on the harness. I installed mine and the right turn signal lit up when the rear defroster turned on. Correct it by following the traces back to the terminal and referencing the new cluster to the old. switch the wires as necessary.
the whole thing should take 10-15 minutes, even with the minor rewiring.
