Dont move the AFM settings, actually thats the last thing u want to do.
You say it didnt move past 3/4 when the arm is fully raised...then thats most likely the prob. But dont be too sure as it can also be the gauge in the dash not giving the correct reading.
As for the AFM, you cant damage it by cleaning it. But since youve most likely found the problem with your gas gauge reading, its if your willing to do it.
All i would suggest, is taking it out and feeling how the flap moves. If it's just even a little stiff, you want to spray some kind of electrical lube on the hinge inside. I use BelRay 6 in 1 and contact cleaner. and the color of the muck that came outa there was worth the clean. No harm done just dont flood it or hold it upseide down when spraying inside, cuz you may get some inside the electrical panel.
