how to tell if i have a blown head gasket - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 9 Old 10-27-2007, 11:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question how to tell if i have a blown head gasket
hey guys how can i tell if i have a blown head gasket??What are the signs and symptoms?
Awheet is offline
post #2 of 9 Old 10-27-2007, 11:59 AM
Holding Off 20th AE GTI's
94DX5Speed's Avatar
Quoted: 0 Post(s)
Overheating, and coolant in the oil are some signs.
1994 Corolla DX 5-Speed with tachometer, working A/C, and a casette player. Everything I need.
*RIP* 11-19-07
Reborn 12-08-07
94DX5Speed is offline
post #3 of 9 Old 10-27-2007, 12:01 PM
Senior TN Member
retiredat44's Avatar
Quoted: 47 Post(s)
water on your spark plugs, water in exhaust.. water dropping...
retiredat44 is offline
post #4 of 9 Old 10-28-2007, 01:06 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
hey guys ok well is this bad cause my dad made it sound bad and now im really nrevous can i jsut buy a new gasket set for 40 bux from advanced auto?
Awheet is offline
post #5 of 9 Old 10-28-2007, 01:20 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hey again i decided to search for other posts on this problom and none of the symptoms they are describing is happening to me. There is no coolant in the oil, but my car smoked not badly, when i reved it into the HIGH rpm's, and it doesnt overheat
Awheet is offline
post #6 of 9 Old 10-28-2007, 05:34 AM
Quoted: 0 Post(s)
coolant in your oil, oil in your coolant, oil/coolant leaks around the head is what I know about blown head gaskets.
One quick check you can do - while engine is COLD, take the rad cap off. start the engine and let it warm up. Look into the rad and watch for bubbles. the bubbles are the exaust gasses leaking into the water jacket, and means your head gasket is sick.
What is the color of the smoke? Blue means it's burning oil. White means it burning water or it's condensation from exhaust meeting cold air.
Puffie40 is offline
post #7 of 9 Old 11-04-2007, 07:17 PM
Quoted: 1 Post(s)
howtotell
Hello friend, dont let that motor overheat or you will blow a gasket. It has an aluminum head. Watch the temp gauge. Most blown hg will spew white smoke. A shop will be quite expensive to do. Prob between 900-1800$. Try replacing the thermostat first. A shade tree mechanic can, (I mean doing it yourself with all the pullys and the kit) do it for 400.$ Its mostly labor charge. Difficulty of 1-10, 4. Dont rule out relays and dead fans first. If you know how to use an Ohm meter that helps with relays. 12volt jumper wires for the fans. How many miles, and did it allready overheat?
wheredoesthisgo is offline
post #8 of 9 Old 11-04-2007, 07:21 PM
Quoted: 1 Post(s)
Post Script: the thermostat does not take 400$ to replace I meant the head gasket doing it yourself. The thermostat is like 15$ bucks and 15 minutes.
post #9 of 9 Old 11-04-2007, 10:36 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
naww i didnt over heat at all never has not once but my dad was like ask those guys on TN and see if you have a blowen head gasket jsut to see what they say the car is fine
Awheet is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Archived Corolla threads
User Tag List
Linear Mode Linear Mode
Back
