Originally posted by samp55
The problem might be something as simple as low fluid. I'm afraid to take it to a mechanic though . He may easily say the problem is something else and have me replace other items besides the fluid as well.
I once took my car to Midas due to a "grinding noise when braking" problem. The mechanic did an overall inspection and told me that besides the brakes, he found cracks in my serpentine belt and that I could lose my power steering if it is not replaced. Maybe it was true but I have my doubts. I had no choice but to replace it. The car was only 3 years old at the time. I thought belts, especially Toyota belts, last for a long time.
Dude no one said to take it to the mechanic, just pop the hood and see if your clutch fluid is low! And if the guy says your belt is cracked but you are not sure you need to replace it, then look at the belt yourself!
It's not rocket science. I'm sure you could find it. If it is indeed cracked, then yes, it needs to be replaced.
Let us know if you needed fluid or it is something else
Good luck.
