1997 Toyota Corolla Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2003, 04:25 PM   #1 (permalink)
View silent66's Photo Gallery
Does anybody have a link to info on the adjustment of the rear brakes and emergency brake on a 97 corolla.....I am cheap and don't want to fork out the 14 bucks for the Haynes manual.........
silent66 is offline   Reply With Quote
Old 09-29-2003, 05:19 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Well the rear brakes are self adjusting.
Just go fast in reverse then slam on the brakes.
Failing that, take off the drum brake covers back there and you will see this little star gear thing. When you turn it, the pads get closer to or farther away from the drum surface. Turn it untill they touch and then back it off a bit. You can also adjust the parking brake cable at the lever. Remove the center console and there is a pretty self-explanitory spinning nut type assembly like on bicycle brake lines or your throttle cable wich you can use to take the slack out of the line...
Chris Corolla S is offline   Reply With Quote
