Originally posted by Alpha
doesn't less weight in front mean less traction since it's FF?? Also, he said he had understeer with his current setup during turns ( with braking...) so wouldn't a light front end make the situation worst?
don't quote me on this, but i think it has to do with tire dynamics.. obviously, your front tires are only capable of providing a certain amount of grip.. during initial turn-in and braking, you're putting a lot of weight on the front tires, and then asking them to grip in the direction of the turn. However the momentum of the car (which is affected by weight) is still pushing forward in the initial direction.. if the force pushing the car forward is too great, then the tires run out of grip to turn the car, and you get understeer..
so if you have more weight over the nose of the car, it will make this problem worse..
more weight over the nose of an FF car will probably give it better straight line traction, but not better handling, since FF cars are (almost?) always heavier in the front than the back to begin with..
anyways, i did a horrible job explaining this and my physics teacher is now hanging his head in shame, but whatever, I know what I mean.
