Lowered my 86 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2003, 02:13 PM   #1 (permalink)
Dis reg!
AEugene86's Avatar
View AEugene86's Photo Gallery
Talking Lowered my 86
just finished this weekend. thankyou baartman and brother for all the help,tools and driveway space. I gave it little road test and so far so good. except now I have a clunking noise after most turns( not load). anybody else experienced this noise after lowering or any suggestions what it might be.
ae86 lowering pics approx 350KB
thanx to baartman for all the help posting the pics and making my new sig
'87 Corolla GT-S HB
AEugene86 is offline   Reply With Quote
Old 10-12-2003, 02:37 PM   #2 (permalink)
View hachi_slow's Photo Gallery
Good job. Approximately how much lower will they go after settling with those springs?
hachi_slow is offline   Reply With Quote
Old 10-12-2003, 04:15 PM   #3 (permalink)
Dis reg!
AEugene86's Avatar
1 in. in the front 1.3 in. the rear
'87 Corolla GT-S HB
Old 10-12-2003, 07:43 PM   #4 (permalink)
View mr_sinister's Photo Gallery
where is the clunking noise coming from?
with my car, if one of the rear springs isn't sitting on the bottom perch properly, a loud clunk is made during hard cornering.. it's quite a loud clunk when that happens..
mr sinister
1987 ae86 - black hatch
--- GTP Light Tune SPL Super Lace Edition
2001 VW GTI 1.8T
--- "Racing" pedals.
my website
mr_sinister is offline   Reply With Quote
Old 10-12-2003, 07:44 PM   #5 (permalink)
btw - did you do that "common brake booster hole repair" yourself, or was that at a shop?
was that new metal welded in there?
mr sinister
2001 VW GTI 1.8T
my website
Old 10-12-2003, 09:55 PM   #6 (permalink)
Dis reg!
AEugene86's Avatar
the clunk definately comes from the left wheel well. during a lefthand corner.
I did it myself with sheet metal from crappy tire. I gotta patch up the inside with something still but it has to be able to withstand extreme heat. will bondo do the job?
'87 Corolla GT-S HB
Old 10-13-2003, 04:18 PM   #7 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Looks good, are those Tokico Blues?
Hows the ride/handling besides the clunk?
Chris Corolla S is offline   Reply With Quote
Old 10-13-2003, 06:01 PM   #8 (permalink)
Den
86 Celica Gt driver
View Den's Photo Gallery
that's what i want to ask
how do you feel after lowering?
better handling?
how much does it cost you in total?
labour + parts
Den is offline   Reply With Quote
Old 10-13-2003, 06:10 PM   #9 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
clunking over bumps usually means your strut mounts are gone.. I should know better.. my suspension is only 1yrs old, KYB struts and APEX springs, and they started clunking at the beginning of the summer.. I'll get the KYB strut mounts as replacement. But if they're more $$$ than the OEM, then I'll just get the OEM ones.
Old 10-13-2003, 10:57 PM   #10 (permalink)
Ha Ha! Noses on dowels!
baartman's Avatar
View baartman's Photo Gallery
could be the strut bearing by the strut tower.
My car:
1988 Mazda 323 GTX. 4WD/Turbo
I miss my 86.
baartman is offline   Reply With Quote
Old 10-14-2003, 08:50 AM   #11 (permalink)
aka doublezero...
View wunderboy's Photo Gallery
I read that when you lower the AE86, you have to shorten a rod, (lateral rod I think) above the rear axel. Did you do this? If not, is your rear axel still centre? Aparently if you go too low, this rod will actually shove the axel out to one side. This may be where the clunking is comming from.
There are those who do things, and those who take credit... The trick is to be in the first group, there is a lot less compitition.
wunderboy is offline   Reply With Quote
Old 10-14-2003, 12:41 PM   #12 (permalink)
The terrorist
View Xenon's Photo Gallery
Hey! I have clunking on my car from the passenger side! That's a strut mount?
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 10-14-2003, 04:31 PM   #13 (permalink)
KDM is in
REN69's Avatar
yeah.. the rubber on the mount has stretched to the point that it doesn't keep the strut rod tight.. therefore everytime the car goes over a bump, the strut rattles.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 10-15-2003, 09:50 AM   #14 (permalink)
i don't think a un-centered rear axle housing will cause a clunking noise.. it might make your tire rub, tho..
mr sinister
2001 VW GTI 1.8T
my website
Old 10-15-2003, 11:22 AM   #15 (permalink)
View neil85AE86's Photo Gallery
make sure your upper shock bolts are tight, their should be two on each shock, one is a lock. The first time I did the springs in my car I had an anoying clunk, turned out to be one of my rear shock bolts. Check the 3 bolts on top of the front strut towers too while your at it.
Are the gland nuts tight that hold the struts in the casing?
You didn't lower it very much, so that's the only things that I could think that would be causing you grief.
As far as the lateral rod, well mine is lowered 70mm in the rear and the tires are perfectly centered.
Neil
Uber D.I.Y. Zenki Turbo
Squirted since '03
1994 Tercel 2dr 5spd
2003 Mazda MPV LX
neil85AE86 is offline   Reply With Quote
