go to crappy tire, auto paint/bondo/fiberglass isle
pick up some fiberglass sheets, fiberglass resin and a bit of body filler
give the inside of the kit near the crack a good sanding and wipe
dip a cut to size peice of fiberglass cloth in the resin (with hardener added of course) and slab it on the back side of the affected areas
get all the air out from under use your fingers, make sure there's enough resin on the cloth for it to spill over the ends of the cloth
you'll need a few layers, so let it dry a couple of hours, overnight preferably, give it a bit of a sanding and do it again
the body filler is for the little bit of a crack that'll be left on the outside
-Nick
