manifolds suck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2003, 08:42 AM   #1 (permalink)
View flynnagain's Photo Gallery
manifolds suck
i have a 1992 corolla, i have my second exhaust manifold in it and its the second time it had cracked in half. i was wondering why it is doing this. i also considered buying a header if there are any even made for this model. are there? if so where can i find one?
its a 1992 corolla dx DOHC 1.6L if that helps
flynnagain is offline   Reply With Quote
Old 10-21-2003, 10:43 AM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Re: manifolds suck
Sounds like excessive heat. Are you missing the manifold heat shield?
Your engine is the 4A-FE, I think pacesetter might make a header for it.
Chris Corolla S is offline   Reply With Quote
Old 10-21-2003, 12:44 PM   #3 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
HP Racing (or something like that) also makes a header for the 4A-F as well.
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 10-21-2003, 01:45 PM   #4 (permalink)
it is a year old manifold, it has a heat shield. i think its just because of too much compression at high rpm's. i am on the interstate about every other day for a half an hour at a time. i dunno.
Old 10-21-2003, 03:00 PM   #5 (permalink)
Guitars and Cars
No, there is something wrong with your car, running on the highway all day long should be fine. Maybe a sensor needs to be replaced? I had a problem on my '84 Camry where the exhaust manifold was always getting warped. I went through gaskets all the time. Something to do with excessive heat there as well, I never figured it out...
Old 10-21-2003, 03:26 PM   #6 (permalink)
View Deep's Photo Gallery
Yeah, how well is your car running? High exhaust gas temps are an indication that your car is running lean. Did you advance your timing by any chance? If the temp of the mani gets too high and is exposed to water, it will likely crack or warp. Same deal with brake rotors.
Deep is offline   Reply With Quote
Old 10-22-2003, 09:50 PM   #7 (permalink)
View 1owner's Photo Gallery
By any chance do you leave late for work in the morning? Jumping in and driving away with a cold engine, then putting the boots to it on an extended high-speed highway run can also do nasty things to a manifold (and other things!) Just a thought.
A lean mixture or a misfiring plug can also overheat things.
'89 Corolla GT-S (RIP 1989 - 2003 very sad!)
'67 Chevelle (2owner)
'10 Passat (1owner)
'84 Honda XL350R (1owner)
All mint!
1owner is offline   Reply With Quote
Old 10-27-2003, 12:29 PM   #8 (permalink)
View neil85AE86's Photo Gallery
I'll put my money on a lean condition. Your injectors could be fouled and dirty, your fuel pump could be on it's last legs, you could have faulty sensors. Any of the above could cause your ECU to go into 'safe' mode, which would retard the timing, as well as try to enrich the fuel mixture. Timing retard will also cause excess heat.
I'd recommend you get your car in to a Toyota dealer ASAP.
Neil
Uber D.I.Y. Zenki Turbo
Squirted since '03
1994 Tercel 2dr 5spd
2003 Mazda MPV LX
neil85AE86 is offline   Reply With Quote
