tranny dip stick fill hole..??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2003, 09:09 PM   #1 (permalink)
View SalEsh's Photo Gallery
i own a 89 4age ae92 gts and im wondering were to fill my tanny fluid cause i just replaced the front boots.... i cant find it lol
SalEsh is offline   Reply With Quote
Old 10-27-2003, 01:12 PM   #2 (permalink)
any one know!??! i really need to know cause i have to fill it back up... and im getting my licence back on the 29th and id like to have a car running
Old 10-27-2003, 02:22 PM   #3 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
Are you asking where the dipstick is, or if one uses the dipstick hole to fill? I can't tell you where it's located, but I can verify that this is where you fill auto trannys.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 10-27-2003, 02:29 PM   #4 (permalink)
View Deep's Photo Gallery
GTS, therefore its a 5spd. There is no dipstick, basically you have two plugs on your tranny, one is to drain (its the big one that needs a 1/4 ratchet to open) and the other is located about 4 inches above it and thats the fill hole. You know when the tranny is full when fluid starts dribbling out. Good luck.
Deep is offline   Reply With Quote
Old 10-27-2003, 02:50 PM   #5 (permalink)
not actual size
brink's Avatar
All gts' are manual? Huh. I did not know that.
-- Jonathan W.
Old 10-27-2003, 02:59 PM   #6 (permalink)
As far as the AE92 and AE86 go. Celicas were available with auto or manual.
Old 10-27-2003, 07:05 PM   #7 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
Deep is correct its a 24mm bolt, first drain the bottom one, than fill from the top one....there only two huge 24mm bolt on the tranny, so its easy to figure out which is which, water flow downwards
you hafto take off the plastic dirt gaurd off to get access to it, so try not to snap those ruusty bolts.
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
