what part of the dash? with the ae92 coupe you need to start from the bottom and work up, that's the only way to do it.....
i just removed the gauges, and that in itself requires quite a bit of removal (stereo shroud, drivers side lower dash, the trim around the steering wheel - the black/smooth one, then the piece that has the hazaard/defroster buttons, then you can access the screws.....
