20v jdm swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2003, 01:24 AM   #1 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
20v jdm swap
Hi, my friend has an 88 gts with the 4agelc in it and we were looking into the 20v jdm swap, anyone have any info on this? Is there anything special about this swap that would need special attention more than any other swap?
Thanks,
Brian
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 11-17-2003, 02:15 AM   #2 (permalink)
In Ur MOM's Pants
RedruM's Avatar
View RedruM's Photo Gallery
WTF is 4agelc???
it's a 4age -
88-89.5 are low compression
90-91 are high comp
ohhh now i see it
4agelc= U mean low comp ... duhhhh
yeah anyways this has been brought up many many many times
do a search and trust me you'll find lots of stuff
keep the signatures clean please
RedruM is offline   Reply With Quote
Old 11-17-2003, 07:13 AM   #3 (permalink)
View micro214_kp61's Photo Gallery
it should be a "bolt-on swap".
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 11-17-2003, 11:19 AM   #4 (permalink)
View Deep's Photo Gallery
Originally posted by RedruM
WTF is 4agelc???
it's a 4age -
90-91 are high comp
ohhh now i see it
4agelc was the california emissions equipped version of the motor.
Deep is offline   Reply With Quote
Old 11-17-2003, 11:21 AM   #5 (permalink)
3s-fte power!
djprefix's Avatar
alright, I'll definately do a search. I find it strange that it would be cheaper to drop in an 11:1 jdm 4age then rebuild his old one :/
Old 11-17-2003, 11:23 AM   #6 (permalink)
3s-fte power!
djprefix's Avatar
Ok I've done a search and I didn't seem to find much in the way of swapping it into anything but the ae86s, and those are mounted front to back rather than side to side which is what I want to swap it into. Will there be a problem with the motor mounts?
Old 11-17-2003, 02:13 PM   #7 (permalink)
the reason why you don't see this type of swap on the net is because it's simple enough that you don't need to see it. now, don't take this the wrong way but if you don't have any experience in swapping this motor i suggest to have an experienced shop do it for you. the amount of time and money that you'll be wasting is not worth it. but if you are confident, make sure to double check everything esp. when it comes to the wiring part. if you have all the proper parts like an uncut harness and ecu, you should finish this swap in no time. the motor should bolt on perfectly to your mounts cause the share the same block origin. a friend of mine did this swap about a year ago and it took them 2 full days to swap the motor in and start it. be careful not to damage the parts of this motor coz it's harder to get replacements for them.
goodluck with the swap! and have you tried posting or searching at club4ag. com? here's another link i got from dori-kaze...
twincam.org
