replace dashboard light 97 corolla CE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2003, 09:18 PM   #1 (permalink)
View anitafagina's Photo Gallery
My left two dashboard light just went out after 100150 miles of use on my 97 corolla CE. I unscrewed the top 2 screws directly above the instruments and that's the only two I see. The left vent pop loose, so I can flash a light in to see what's behind it and how to reach the back. It looked pretty cramped. Please help. Thanks, Anita
anitafagina is offline   Reply With Quote
Old 11-20-2003, 10:49 AM   #2 (permalink)
View KaMLuNg's Photo Gallery
after u take out those two screws on the top that plastic frame should just come off... if not take a flat screwdriver and carefully ease it off.. then there should be the screws holding the cluster in...
'01 GS430
'07 Acura TL
'98 3.2 TL
'07 Rolla LE
KaMLuNg is offline   Reply With Quote
Old 11-21-2003, 02:12 AM   #3 (permalink)
I got some diagram from the library. It looks like there are two clip-on at the bottom to hold the frame in. Now, I will need to remove the Cluster Finish Panel before reaching the Combination Meter? Are the light bolbs inside the Combination Meter unit? (i.e. I will have to take the Combination Meter apart?) Will that reset things or touch things which I may mess things up? I don't want to set off the airbags...Thx
Old 11-21-2003, 09:16 PM   #4 (permalink)
when u get the cluster out just diconnect all the harnesses in the rear the bulbs should plug straight into the back of the cluster...
'01 GS430
'07 Acura TL
'98 3.2 TL
'07 Rolla LE
