QUestion... regarding sr5.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2003, 11:17 PM   #1 (permalink)
View [sPooN] aE86's Photo Gallery
hello everybody.. haven't logged in for a long....... time but how's everyone doing??
Kevin if you see this WHERE HAVE U BEEN ALL THIS TIME??? i think i saw your car at elite this summer
ok back to topic....
i just wanted to know if a GTS rear axle just BOLTS right up to an SR5??
and how hard is it to add the 3rd pedal?
Thanks
Ken
[sPooN] aE86 is offline   Reply With Quote
Old 11-23-2003, 12:00 AM   #2 (permalink)
Operation Front Bumper
2advanced's Avatar
View 2advanced's Photo Gallery
what do you mean 3rd pedal?
clutch pedal?
2advanced is offline   Reply With Quote
Old 11-23-2003, 07:35 AM   #3 (permalink)
View Rust_bucket's Photo Gallery
I did one last week... It actually bolts right up! Well some of it... The Gts full rear end bolts up nicely to the SR5... But if you try to take the SR5 rear end and bolt it up to the GTS you'll see that the torsion bar (The bar that goes from the drivers side rear axel ACROSS to the passenger side rear axel) Do not bolt up correctly... If you want we can keep in touch and I can guide you through it... Also the whole pedal assembly is KINDA a bitch to take out of the GTS... you have to take out the WHOLE dash... If you plan to do this swap you have to take other goodies of the GTS.. I.E: Booster, Master, Perportioning valve and such...
Proving people wrong 10psi at a time... t'ill the motor blows then I have no more to prove really...
Rust_bucket is offline   Reply With Quote
Old 11-23-2003, 10:06 AM   #4 (permalink)
rust bucket,
Here's what i COULD have at the momment and i know i'll need a hell lot more to complete this so i'm gonna see what u guys think
IN STOCK:
-84 SR5 (no emissions!!!)
-complete 4AGE redtop (tranny, ECU) but do i have to move throttle body?
-full gts rear axle
NEED:
-gas tank
-gts cluster? the sr5 one doesn't read from the gts tranny right?
what else should i consider??
Thanks again
Ken
Old 11-23-2003, 10:12 AM   #5 (permalink)
The best thing is to have 2 cars, an SR5 and a beat up GTS... You'll need to locate a couple stuff... IE: Clutch pedal assembly, gauge cluster, Tranny mount (Cross member), Vehicle speed sensor, slave, perportioning valve, booster, master cylinder, GTS brake cables and such...
Old 11-23-2003, 10:13 AM   #6 (permalink)
Why do yoou need a gas tank?
Old 11-23-2003, 01:32 PM   #7 (permalink)
lol cause the one needs replacing hehe
hmm already have the pedal assembly
new brake lines shouldn't cost that much and didnt' know about the crossmember... damn
and i'd also need both master AND slave
what's the booster?
how possible is it to remove and install the rear axle at home?
Ken
Old 11-23-2003, 02:03 PM   #8 (permalink)
It possible to do it at home... it would be a bitch! but it's do able... Need SEVERAL jack stands though... you need the master and booster and perportioning valve because your going to be running 4 wheel discs as oppose to only 2 wheel...
Old 11-23-2003, 05:00 PM   #9 (permalink)
View martiniracing's Photo Gallery
good luck on building your sr5 into a jt2ae88!
booster meaning brake booster
sell your car free!
www.projectsource.ca
martiniracing is offline   Reply With Quote
Old 11-23-2003, 05:58 PM   #10 (permalink)
that clears it up..
best possible solution is to find a parts gti eh?
hmmm.... hard..
Old 11-23-2003, 06:04 PM   #11 (permalink)
View AssDrag's Photo Gallery
Originally posted by [sPooN] aE86
rust bucket,
IN STOCK:
-full gts rear axle
NEED:
-gas tank
Thanks again
Ken
i think you might need the fuel lines too cause the 4age is fuel injected. also you you need a adaptor plate for the intake manifold cause the hose is going in the wrong direction. some seats would be good too if your going for the full conversion
AssDrag is offline   Reply With Quote
Old 11-23-2003, 09:54 PM   #12 (permalink)
operation boro thunder
View project trueno's Photo Gallery
is this project in a hurry?
i may or may not have the solution to your problems, but anyway just keep this thread BuMpEd
project trueno is offline   Reply With Quote
Old 11-23-2003, 10:21 PM   #13 (permalink)
fill me in some info!!
would january be hurry or not hurry?
well target would be jan - feb
Old 11-23-2003, 10:57 PM   #14 (permalink)
ohh nice, what remaining parts do you need?
Old 11-23-2003, 11:54 PM   #15 (permalink)
In Ur MOM's Pants
RedruM's Avatar
View RedruM's Photo Gallery
i'd say jan feb would be a hurry but it depends on how much time you put in everyday
target time i'd say would be march april
keep the signatures clean please
RedruM is offline   Reply With Quote
