88 Corolla auto tranny swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2003, 08:57 PM   #1 (permalink)
dx-r's Avatar
View dx-r's Photo Gallery
I have a 1988 Corolla that was blessed with a 3spd automatic tranny :o. I was wondering if it would possible to swap out the tranny for a 4spd or a 4spd with overdrive? Will is be a straight swap? What other year/trim level Corolla trannies can i use??
dx-r is offline   Reply With Quote
Old 11-23-2003, 09:37 PM   #2 (permalink)
Operation Front Bumper
2advanced's Avatar
View 2advanced's Photo Gallery
you can put any tranny you want that comes from a 4afe, or 4age engine
i did the auto to manual 5spd swap not too long ago
i took it out of a 89 carb corolla sedan
the only electrical wires going to the transmission is 4 wires
2 for postive and 2 negative
1 is for your neutral safety swich to make sure you are in neutral to start your car
and the other is for your rear reverse lights
there is also one cable to the tranny which is your speedo cable
thats about it
hope that helped
2advanced is offline   Reply With Quote
Old 11-24-2003, 12:34 AM   #3 (permalink)
dx-r's Avatar
Thanks for your help.
What year/model Corollas has the 4afe and 4age engines?
Old 11-24-2003, 10:22 AM   #4 (permalink)
dx-r's Avatar
What is needed for a manual conversion? Does the 88-92 Corollas use a cable or hydro tranny?
Old 03-25-2007, 11:18 AM   #5 (permalink)
View NiceSR5's Photo Gallery
If you never did an auto tranny to manual swap before, its best to get a friend was has. The flywheel is different, your gonna need to buy a clutch and the shifting cables are needed from the donor car. It's not a drop in plug and play thing. The clutch master cylinder needs to be added, slave cylinder, different tranny mounts and so on. I've done 2 myself and I practically moved half the car in parts on on 1st one. I suggest assisting someone else 1st before you start hitching rides for a couple of days doing your own.
Your 88 should have a 4AF which is carburated and the 4AFE started in 1990 and they are fuel injected. The trannys are the same. Corollas 88-92 are great on interchangeable parts. You gonna like that forth overdrive gear...saves gas too. See if you can pull the shifter from that donor car. There may be an overdrive button on the shifter shaft. I'm trying to sell an auto tranny, the one you need but I'm over 3000 miles away in CT. Good luck
NiceSR5 is offline   Reply With Quote
Old 03-25-2007, 11:35 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
It helps to look at the dates on the threads before you post on them, this one is 4yrs old and chances are the man you're addressing is looong gone from this site.
Old 03-25-2007, 02:57 PM   #7 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Find a C-52 trans (5 speed manual). You will see that the C-52 bell housing has 2 starter humps in it (right and left side). C-52 was put in some corollas from 1988 to the mid 1990's.
retiredat44 is offline   Reply With Quote
Old 03-27-2007, 01:13 AM   #8 (permalink)
on full afterburner
Gameroom cash: $1347397
Old 03-27-2007, 09:55 AM   #9 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
you guys should lock threads automatically after a year
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
