Idle problem. Need Help... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2003, 09:59 PM   #1 (permalink)
View oreo's Photo Gallery
hey guyz. I have an 87 GTS Coupe (4AGE). When the car is cold and i start it up it idles around 1200 rpm then as it warms up it slowly goes up to 1800 or sometimes 2000 rpm. and when its warm it revs up and down from 1300 to 1700 rpm. Has anyone had this problem b4. What did u do to fix it? thanx allz....
i checked all the lines and all seems fine. intake is bolted on tight.
its drivin me nuts.
oreo is offline   Reply With Quote
Old 11-26-2003, 10:48 PM   #2 (permalink)
operation boro thunder
View project trueno's Photo Gallery
check carefully for vacuum leaks, use soapy water on the connections, or poke around the engine bay with a thin hose and listen for any air leaking...idle air control valves, VSV, see if the dashpot is stuck, EGR, etc
if that doesn't solve the problem, then i would look into the fuel system, dirty fuel filter, check the pressure
all the basic maintainence stuff are ok right? spark plugs, air filter, dizzy cap and rotor?
project trueno is offline   Reply With Quote
Old 11-28-2003, 02:41 PM   #3 (permalink)
i checked all the vacuum hoses,.. they all seem to be fine,..unplugged the vsv and it made no difference,.. just put in new plugs.. cap and rotor seems to be fine... i'm wondering if its an O2 sensor problem.
i just put the car on the road 3 weeks ago and it started in the first week.... (after i started revvin it at past 7... )
Old 12-03-2003, 12:30 PM   #4 (permalink)
Back From the Dead
CorollaINC's Avatar
View CorollaINC's Photo Gallery
Im having the exact same problem, i dont have a clue what it is, so when you find out let me know, and if i know ill pm you.
I . N . C
ALI
CorollaINC is offline   Reply With Quote
Old 12-09-2003, 12:13 PM   #5 (permalink)
problem solved...
i took out my throttle body and looked underneath the bypass valve where the coolant goes through and found an rtv sealer that got stuck there. i guess it kept my cold start valve open. once i took it out and put it back in. my idle problem is gone.
so try the same thing and maybe u have something blocking the lines.
now i don't have to feel ashamed at a stop light anymore.... hahaha good luck
Old 12-13-2003, 05:13 PM   #6 (permalink)
View cray_ze's Photo Gallery
TPS sensor
I had the same problem with my honda....it was the thottle position sensor. its that little knob that you turn with the screw driver located by the intake. Some one has probably set it to a higher position than it should be..
Friends don't let Friends Drive Stock
cray_ze is offline   Reply With Quote
