[QUOTE]
Originally posted by Xenon
[B]You're most likely going to pay an arm and a leg for a suspension from Toyota! Why don't you do some homework and find out how much after-market struts go for and maybe you'll get something for a better price?!
I went to my mechanic... everything on suspension is in very good condition, except shocks - I will reffil the shocks and put a new seals. Also I will change that rubber which is broken (strut abosrber rubber), and that protective rubbers which are mounted around shocks (to prevent dust and dirt going into piston)... Well, when outside is very cold the clunk is heard very quiet and not so often, but when it is hoter it will sound more loud and more often, because that shock has a little bit oil in itself (it cannot leak to be dry) so it get stiffer when it is cold
If my arm and leg went off the car will be swaying like the airplane in the stiff crosswind
but my car is very very stable. And I saw that the wheel is bouncing up down a lot more than the other one when driving over bumps - definite sign of a broken shock
