Well, EFI is expensive.. and it's computer.. and i hate computers... I like things where I can actually take them apart and see the problems and fix them.. not sutpid ass diagnostic codes.. just my preference..
I don't have any tuning problems like you did, with the difference in air temps with my weber now.. Infact when I took the car out for a drive a month ago when I was just gettin things setup and I didn't have the hood on.. I came around my neighborhood.. turned up my street and stomped it.. and the tach took off like never before.. but now with the hood on and the carb only getting the engine compartment hot air.. she doesn't move like she did that night!
Back then I had the spark timing off.. and the crank timing and tons of crap wasn't timed right.. so I'm really curious as to how much of a punch I will get with a ram-air setup breathing from a scoop I plan to make on the right front 1/4 panel..
But I don't want to drop more cash into this engine for anything if I can't turn it into the racing engine I want.. As it is now it's a nice engine and very reliable..
I want an engine that is basically more powerful from the factory so it's fast on the street.. in my light sr5 ae92 coupe it will haul ass.. plus over time I want to build it up.. SO I was planning on the 4AGZE and carb'ing it.. that would land me at the 160-180HP range stock with the carb on it if I got the Jspec engine.. Then get the engine up to a nice 220ish.. it should make a pretty fucking fast car..
My other issue is I like my automatic tranny for road use.. and when I want to race around and have control of the gears I just slap stick the tranny.. I'll run 1st gear up to like 7,200RPM before I'll slap it into 2nd gear.. and that way I'll be at a nice like 4,500ish on the tach... Run 2nd to like 6.4K rpm's before I'll slap it into Drive.. but then I'll keep the overdrive off..
Ah.. it's nice.. and I keep the 4AF at high RPM's cuz it needs them..
So...
I'd like to keep my automatic tranny.. and for now I am going to get into some racing events with my 4AF to learn the skill better .. but eventually I just want to get a new engine whether it's a mix of blocks like a red top bottom and a blue top small port top or a 4agze.. whatever.. and build it up in my spare time and then drop that into my coupe.. got me?
