Originally Posted by sok
hey i'm wondering if anybody's had probs w/ their new horn yet.
yea. it sucks. plain and simple, i bought the new horns before I even took delivery of the car. i knew they'd just plain suck
does this corolla need a relay for an aftermarket horn, or a higher amp fuse? i have a feeling the crappy horn setup in there now isn't wired to carry much current.
for most horns out there, probably not.
i made up a wiring harness out of 12 gauge wire to get power directly for my horns. i know its overkill, but the horns are a tad bit louder and I don't have to worry about hacking up my car's electrical system since it takes less power to power the relay than it does to power the factory horn.
does anyone know if the horn closes the circuit to ground or to the power source? or, do aftermarket horns just plug right in w/ no worries
the factory horn uses a single positive wire. the horns ground themselves via the mounting bracket. if your aftermarket horn doesn't ground themselves similarly (many don't) then you will just have to add an extra wire to ground the horns.
