Compression - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2004, 11:07 AM   #1 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Compression
Has anyone here done a compression check on their corolla? What did you get, I got 120 from 1,2 and 4 cyls and 60-90psi from 3
Old 01-04-2004, 01:51 PM   #2 (permalink)
operation boro thunder
View project trueno's Photo Gallery
uh oh....90psi?
its supposed to be around 130-170psi IIRC
edit: ^specs for 4AGE
project trueno is offline   Reply With Quote
Old 01-04-2004, 01:58 PM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
time for a rebuild
-Nick
Nick is offline   Reply With Quote
Old 01-04-2004, 02:02 PM   #4 (permalink)
View Deep's Photo Gallery
I'm scared to do a compression test on my car, but I probably should. Anyone have a guage?
Deep is offline   Reply With Quote
Old 01-04-2004, 02:42 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
a rebuild at 57000km? I was just seeing if I have a burnt valve....
Old 01-04-2004, 03:02 PM   #6 (permalink)
Nick's Avatar
possibly, either way you're gonna have to tear into it
try a leak down test, see if its the rings
-Nick
Old 01-04-2004, 03:46 PM   #7 (permalink)
aka TRD_roLLa on CC.com
View ractive_roLLa's Photo Gallery
what should it be normally for 4a-fe??
and how much would it regularly cost to perform at a shop?
ractive_roLLa is offline   Reply With Quote
Old 01-04-2004, 04:19 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Its not the rings, I know I have a burnt valve because all the signs point to that... I was just checking the compression on it... sucks. Time for new valves... titanium anyone?
Old 01-05-2004, 10:27 AM   #9 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
Re: Compression
hAHAAAAAAAAAAAAAAAHAHAHAHAHAHAHA
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 01-05-2004, 10:28 AM   #10 (permalink)
Boro Box Pilot
boroEF's Avatar
buy a guage, it's probably cheapest
4afe has compression in the 9s correct? at least around 160 psi man!
The boro guru
boro song
"boro boro boro
Old 01-06-2004, 08:26 PM   #11 (permalink)
how much does a gauge cost about?
and how would i perform this check?
Old 01-06-2004, 09:55 PM   #12 (permalink)
^you want to test the air pressure inside your engine, but DO NOT want actual combustion to take place. So you eliminate fuel and spark
for your corolla you can just pull out the EFI fuse, as for spark there're many ways of doing it, i prefer just taking out the wire between dizzy and ignition coil
remove spark plugs as thats where the valve of your gauge will plug into......before cranking the engine make sure your battery is capable of bearing the load....if you have a battery charger connect that to your battery while you do the test
then crank away! When you hear 4 cranks (you can see the needle on the gauge move up and up and up) stop, and if you wish spray a bit of engine oil inside the cylinder, crank a bit to mix it up, then do the test again and see if the oil affected the compression reading significantly
do the same for rest of the cylinders, compare results...
