It's always spring. you car has a strut. In order to change the strut on the car you need to remove the spring on it and mount it on the strut you are installing, for that operation you need a spring compressor and that would be the only way to do it. It is dangerous because in case you don't tighten up right or forget to do something there's a chance that the spring may pop out of the compressor and that is a lethal thing.
I would recommend you take it to a mechanic unless you have the proper tools and someone to help you as well as guide you through the process.
My sexy AE92 http://members.cardomain.com/ababan
