Hi,
I had problems with my heater fan working only on some settings.
Since then the car was parked for about 2 months.
Now the fan doesn't work anymore.
So I started ripping appart the dash, and here is what I found:
As soon as the switch is moved beyond the "off" position, a relay click in the dash.
I read the voltage on the blower connector, and it's 12volts only at the 4th speed.
I read here about the resistor pack, so i checked it and the smaller resistor was broken. I soldered it back on the connectors but a little shorter (i removed th broken part and soldered the rest of the loop). I tested it and the current flow thru all 3 resistor.
Now I hav 12v on all fan settings at the blower connector.
But the blower doesn't turn.
So I tried to connect an old computer PSU (the 12v output) directly to the blower and it works.
Now I'm stumped
. Is it possible that there is 12v but not enough amp? Would it be the fault of the switch?
Thanks!!!
