Urgent ABS Problem to be solved - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2004, 12:51 PM   #1 (permalink)
View dkeenan's Photo Gallery
Hi all.
I was installing an alarm in a 2001 Toyota corolla. After installation I found that the ABS and the handbrake warning light were on. I've checked all of the connections and all of the fuses below the steering column. (The car is a right hand drive). I did unplug some connectors which i then re-inserted. Can anyone please tell me the possible cause for this please.
Thanks.
dkeenan is offline   Reply With Quote
Old 01-10-2004, 07:44 PM   #2 (permalink)
View Morpheus's Photo Gallery
Do the handbrake and brakes still work fine? I mean you can live without it and from what I've heard ABS problems are expensive to fix.
Morpheus is offline   Reply With Quote
Old 01-10-2004, 07:52 PM   #3 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
Low Brake Fluid?
- Vince
VVT-i Owns is offline   Reply With Quote
Old 01-11-2004, 01:23 AM   #4 (permalink)
Banned
View Punisher's Photo Gallery
wow that does sound urgent
Punisher is offline   Reply With Quote
Old 01-11-2004, 11:31 PM   #5 (permalink)
View hdsalinas's Photo Gallery
On my familys 96 Blazer I have installed a switch that cuts the flow of electricity to the ABS fuse shutting it off .
Why, because ABS doesnt work well on dirt or gravel roads. I feel that I have more control with the ABS off. I only use this switch when I need it and when I do the Brake light turns on.
So it might just be a burnt fuse
Hector David Salinas
1999 Corolla CE
(American Version)
hdsalinas is offline   Reply With Quote
Old 01-15-2004, 03:00 PM   #6 (permalink)
Cheers!
The lights went out a few minutes after starting the car, so i presume the computer just had to reset itself or something.
Thanks again.
