problem with clock and radio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2004, 04:23 PM   #1 (permalink)
View comet's Photo Gallery
Hi,
I have a 96 corolla. All of a sudden, the clock light is gone and the radio cannot remember the stations. If I tune my radio to a station and then turn off and then turn on the car, the station is lost. My frend told me that the clock problem may be a fuse problem but why did the two happen at the same time. Any idea?
Thanks.
comet is offline   Reply With Quote
Old 01-14-2004, 03:11 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Probably because they run on the same fuse.
BUT, if it was the fuse that was gone.. you wouldn't have radio OR the clock working at all.. most likely your battery is not holding charge properly. It happened to me a few years ago with my dad's car, the battery kept resetting everything because it was pretty much dead.
Old 01-14-2004, 03:13 PM   #3 (permalink)
üb3r g33k
O 16581 72452 5's Avatar
View O 16581 72452 5's Photo Gallery
I've the same problem in my AE86, but i just don't care.
http://www.mazdaperformance.net
http://www.midwestrx7club.com
O 16581 72452 5 is offline   Reply With Quote
Old 01-14-2004, 06:39 PM   #4 (permalink)
Thanks for your reply. I don't see the clock light so I don't really know if the clock is working or not :-) sorry.
Yes, it may be the battery like you said, because the 'ceiling' light sometimes works and sometimes doesn't.
Old 01-14-2004, 06:43 PM   #5 (permalink)
üb3r g33k
When the engine is running or off?
Old 01-14-2004, 11:47 PM   #6 (permalink)
The terrorist
View Xenon's Photo Gallery
You might've shorted out something while installing the deck in the car, that's about the clock.
The deck problem is a common mistake, you might have exchanged the constant/memory (yellow) and ignition (red) wires. Therefore everytime you turn off the car the deck completely turns on because the memory is not connected to a constant supply to hold the stations.
Check your wires..
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 01-15-2004, 05:33 AM   #7 (permalink)
üb3r g33k
Check your wires..
Sounds to me like he's discussing the factory stereo, or if not, it sounds like he had an aftermarket one installed. No offence to him, it just doesn't sound like he has the knowledge to install it himself.
Old 01-15-2004, 11:56 AM   #8 (permalink)
The terrorist
If you're referring to a factory Toyota Radio that you haven't played with, then it's definitely a fuse... But check the wires if you just installed an aftermarket deck..
Good luck and tells us what happens..
Old 01-18-2004, 03:45 PM   #9 (permalink)
The clock and radio were original and they just stopped working. I will try replace the fuse. Thanks all. I will let you know if that's the problem.
Old 01-30-2004, 10:15 PM   #10 (permalink)
Sorry to take so long to reply. Yes, it was the fuse. Now radio program, clock and ceiling all work.
Old 03-19-2004, 11:48 AM   #11 (permalink)
View Jenavive's Photo Gallery
comet(or anybody)-would you mind letting me know just what the thing looks like? I have opened the panel on the driver's side, but I could not tell which one was the radio/clock fuse. Please help-I miss my radio
Jenavive is offline   Reply With Quote
Old 03-19-2004, 12:14 PM   #12 (permalink)
View homeguard's Photo Gallery
just check them all.
88 Corolla Sedan 238k miles
homeguard is offline   Reply With Quote
Old 03-19-2004, 12:34 PM   #13 (permalink)
üb3r g33k
I checked the fuse while i was under there running the cable to relocate my battery. Fuse is fine. *shrug*
Old 03-19-2004, 12:40 PM   #14 (permalink)
OK but WTH does the thing look like? I don't see anything that looks like the fuses in the engine or the storage compartment. Does it say anything in particular?
Old 03-19-2004, 01:11 PM   #15 (permalink)
View 1GR-FE's Photo Gallery
if you are using a cell charger or something in other than the cig lighter you can blow fuses like that, happens all the time
1GR-FE is offline   Reply With Quote
