weber tuning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2004, 10:42 PM   #1 (permalink)
View mschor's Photo Gallery
weber tuning
Having some minor difficulties with a newly installed weber 32/36. It hesitates when I press the throttle, but then catches and pulls well at high rpm.
Also, it diesels (runs a few seconds after I shut off the engine). Is it running too rich? I followed the instructions for tuning, and it idles well. Send your expertise please.
*Also, about the extra emissions tubes, should I just plug them off? (they are mostly still open and unconnected now, could this be a reason for described conditions?)
thanks for the help
mschor is offline   Reply With Quote
Old 01-17-2004, 11:45 PM   #2 (permalink)
Banned
View Punisher's Photo Gallery
Ahhh which engine bud? I know EXACTLY what you are going through as I was running a 32/36 as well.. tell me which engine u are running and what modifications
Punisher is offline   Reply With Quote
Old 01-18-2004, 12:13 AM   #3 (permalink)
Banned
oh, if u have any pics to put up of the weber installed do so.. how did you setup the throttle linkage?
Old 01-18-2004, 07:07 PM   #4 (permalink)
weber tuning
3TC, man! Don't you remember? Yeah, that's the engine, any help would be great.
Old 01-18-2004, 07:12 PM   #5 (permalink)
Oh, yes the throttle linkage is a bent and beat up version of the original. I just bent the bracket with vice-grips and hammer to bring the cable in better alignment with the linkage. Not enough though. It doesn't stick, but it's not real smooth at the foot either, which brings another question: is it normal for the accelerator to be stiffer with a weber than stock?
a dios
Old 01-18-2004, 10:22 PM   #6 (permalink)
Banned
Hmm.. i don't know with the 3TC.. but you haven't told me any engine mods u have.. it may very well be that the jet size is to small.. but idk.. I was having a lot of problems with mine and I think it's cuz the jet size was to small and that I didn't have the tranny hydraulic downshift line adjusted tight enough on the throttle linkage.
I was having the same issues as you.. and what I did to get rid of the dieseling was I advanced the spark timing.. right now it's sitting at full advance.. 87 oct. pump gas.. and no pinging
Old 01-20-2004, 10:19 PM   #7 (permalink)
weber tuning, stiff pedal movement
This is my first mod, rest of engine is stock. I'll try to get a picture soon. Someone on club4ag said the tubes should all be plugged except the crankcase breather hose, which needs a filter on it. I think my 3TC has two breather hoses, one on top, and one coming from DOWN BELOW.
again, anyone know about stiff pedal movement on webers? Is it normal or just my screwed up linkage?
Old 01-20-2004, 10:22 PM   #8 (permalink)
Banned
View |PuNiSh3R|'s Photo Gallery
I couldn't tell you about the stiff throttle.. I'd have to see pics of your linkage setup.
And no, all the lines do not need to be plugged..I don't know what is under the hood of your car.. so I can't tell you as I run a 4AF.. but I mean to a degree you can reconnect fair deal of emissions.. You can certainly have the EGR connected.. vacuum advance.. blah blah blah.. the weber only has a few vacuum ports on it.. but using T connections and stuff uc an reconnect a bunch of the old stuff.. It's up to you.. if you don't care just rip all of the shit out .. Like I've done to accomidate my quad Keihin carbs... Everything under my hood for the stock carb was useless.. I ripped it all out.. only thing I have is EGR and some cruise control vacuum lines and the vacuum advance
|PuNiSh3R| is offline   Reply With Quote
Old 03-25-2004, 12:41 PM   #9 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $249101
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
i have a 45 dcoe on my 3tc and it is kinda stiff but just lube it up(the gas cable) and it should be fine
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 03-29-2004, 09:08 AM   #10 (permalink)
View l_touring_dude's Photo Gallery
I think the emissions tubes should be plugged
2000 Toyota Corolla 4wd L Touring Wagon (AE104 with 4A-FE)
l_touring_dude is offline   Reply With Quote
Old 03-29-2004, 09:34 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Where are you getting the vacuum for those? got a pic?
