Originally posted by Chris Corolla S
He's talking about outside ambient air temp, not engine temp...
Your right, he is talking about the outside temp. But silverstreak is also right. The sensor is at the front of the rad at the bottom. It's attached to a black wire that runs down the rad.
You only need a screw driver to take the cluster out. Philips head.
To get the right milage your gonna have to unscrew the whole speedometer from the back 5 or 6 screws I beleive. You gotta replace it with your original.
If it has a white face then its more then likely indeglow gauges. make sure to get the power supply with it.
Good luck
