Crazy Sound from Rear End - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2004, 01:02 AM   #1 (permalink)
D1 Champion
Takeshi_Nakazato's Avatar
View Takeshi_Nakazato's Photo Gallery
I just bought an 86 GTS coupe and I had to drive it out of a parking garage to get it towed home (couldn't get a temp). Anyways, on the way out, as I went through the gears, from the back of the car, it's making a high pitched noise. Gets higher as I speed up, basically, the faster the back wheels spin, the louder it gets.
I was wondering if anyone knew what it could be? I was thinking, because the e-brake is seized up (stuck down, can't pull it up) that it's scraping the pads slightly against the rotors in the back and scraping really bad. I haven't had a chance to take anything apart because of the cold and I was wondering if anyone had any insight before I tryed anything
Thanks
Roby
1986 Corolla GTS Coupe (For Sale)
New Car Coming Soon!
Click Here for Sale Thread!
Takeshi_Nakazato is offline   Reply With Quote
Old 01-21-2004, 01:13 AM   #2 (permalink)
View hachi_slow's Photo Gallery
Wow Roby...where do you find these things? Anyways..could it be a bearing?
hachi_slow is offline   Reply With Quote
Old 01-21-2004, 01:57 AM   #3 (permalink)
D1 Champion
It seems to be a talent of mine to find good deals. I have no idea what it is. Maybe if you aren't busy sometime, you can pass by and help me figure it out.
Old 01-21-2004, 02:45 AM   #4 (permalink)
Sure...but it's kinda getting really cold! Find me a coupe too!
Old 01-22-2004, 03:11 PM   #5 (permalink)
View TofuRacer's Photo Gallery
Your problem, or rather problems, might be the brake pads from the rear, the scraping noise that you are hearing might be coming from the brake indicators, these produces a scraping noise if the brake pads are worn. However, you do have to change both the pads and the rotors (Go with Brembos ). On the other hand, your problem with the Ebrake could be that the cable line from the ball of the switch is cut off, or there is a frozen or gunk build up from your brake line, or even the whole Ebrake assembly is messed up (this is usually caused by Drift racers who depend on their Ebrakes for drifting ). Anyhow, check those problems out!
TofuRacer is offline   Reply With Quote
Old 01-22-2004, 03:16 PM   #6 (permalink)
View micro214_kp61's Photo Gallery
jack up the car and spin the back wheels manually! if it's not the brakes, it might be the wheel bearings need to be replaced. goodluck bro and a nice find!
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 01-22-2004, 07:04 PM   #7 (permalink)
D1 Champion
Thanks for all the info guys, once I can go outside for more than 5 minutes without freezing my nuts off, i'll give them a try.
Old 01-22-2004, 07:17 PM   #8 (permalink)
Banned
View |PuNiSh3R|'s Photo Gallery
I have brembo front cross drilled n slotted rotors and rear Bendix rotors in the back on my '89 sr5 coupe.. *yes I did the rear disc swap*
|PuNiSh3R| is offline   Reply With Quote
Old 01-24-2004, 04:58 AM   #9 (permalink)
View EMEX's Photo Gallery
Or simply it might be because it is too cold. Maybe try puting it in the garage and warming up the back of the car somehow and then lift the car and manually test yeach wheel. Sometimes problems can accur because of weather conditions.
Life is a game, play by your own rules.
EMEX is offline   Reply With Quote
