94 corolla rattle idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2004, 11:44 AM   #1 (permalink)
View rmiller's Photo Gallery
Unhappy 94 corolla rattle idle problem
My 94 corolla shakes and rattles at idle even when it is warm. Any ideas of adjustments to fix this problem. It seems to run fine at higher speeds.
rm
rmiller is offline   Reply With Quote
Old 02-15-2004, 11:55 PM   #2 (permalink)
View reym's Photo Gallery
Is it a caburetor type engine?
reym is offline   Reply With Quote
Old 02-19-2004, 07:21 AM   #3 (permalink)
View MX265's Photo Gallery
My old '94 started doing that right around 60,000 miles... I threw in a new set of plugs and wires, tossed on a new accesory and timing belt and had the tranny fluid swapped...This seems to have helped a bit...You may also want to have the injectors cleaned at a dealer, because those bottles of FI cleaner only do just so good.....
my '99 will be getting the same treatment here shortly....that is except for this one has a timing chain, so I don't need to swap it out yet...
MX265 is offline   Reply With Quote
Old 02-19-2004, 06:17 PM   #4 (permalink)
View RADMAN's Photo Gallery
The best way to get rid of it is to do a full tune up and check all the engine mounts to see if any are worn out.
RADMAN is offline   Reply With Quote
Old 02-20-2004, 03:30 AM   #5 (permalink)
Gameroom cash: $134355
i had this problem on my 4a-fe.... i started to fix it by tightening the throttle cable... it helped... would have helped even more if i had known there was an actual throttle body adjustment screw... there's a plastic cap on it.. pull the cap off (dime sized) and adjust it until the motor stops surging....
