help: corolla hesitation
Someone please help. I have an 89 Corolla with a carburetor. My problem is that it hesitates occasionally and it happens at different engine and vehicle speeds. It just happens out of the blue. I don't know if it's a misfire, but I'm pretty sure it's not detonation because there is no sound during the hesitation. Sometimes it's for a quick second and sometimes it happens 3 or 4 times consecutively.
There has been a "check engine" light only about 5 times since the problem started about a year ago and it will go off as soon as I turn off the engine, but will not return when I turn the car back on.
When I changed the spark plugs, spark plug wires, distributor cap and rotor, it worked perfectly for a few months and then the problem returned. I checked the spark plugs recently and it looks fine. Any suggestions on what else I should check or quick tests I can perform?
