"Question.... how much difference would it make between keeping a stock air intake but swapping the filter with a K&N and an Injen intake"
If you remove the airbox resonator (below the box in the fender), and snorkle, and put a K&N Panel filter in your airbox, then you might see a 2 HP gain in the mid-high end of the revs.
The Injen Cold Air might net you as much as 6HP in the high end.
As always if you drive through a puddle deep enough to cover the whole cone filter on the Injen intake, it will ruin your engine.
"and one other thing how much would it cost to have someone install a turbo into a car, like a rough estimate?"
As a point of reference the Stafford Fabrications (southern CA) complete turbo kit for an '04 rolla is somewhere around $3,000-$3,500.
I know someone with an '04 Manual Trans Rolla with grounding wires, TRD Cold Air, cat-back exhaust, and he dynoed at 128HP to the wheels.
