so... as some of you probably knew... i was having a problem of frying ignitors..... (and for those of you completely in the dark.... i'm running a 4a-ge off of a 1990 4a-fe ecu and wiring).... the problem with the ignitor, is that in the 4a-fe it's built into the distributor... the distributor acted as a heat sink.... w/o the ignitor in the dizzy it didn't dissipate heat when 2 attempted trials failed (this one hasn't failed... yet)
So..... what was the idea? use the 4a-fe distributor as the heat sink & just mount it in the car under the dash somewhere (i have yet to do that... i'm keeping an eye on it making sure it doesn't overheat)....
as an added amount of heat dissipating action.... i mounted a heatsink on the backside of the ignitor, and a 12V computer fan to the heat sink.... then, i mounted another (slightly larger) 12V computer fan on the backside of the old distributor cap (after i removed the wires, of course). I removed the magnetic pickups from the inside of the distributor, then cut the shaft down to fit the ignitor w/ heatsink/fan in there..... (i will try and get the rest out... but it's not easy)
here are some amusing pictures (sorry about the bright ones.. the didn't turn out like i wanted :roll: )
^^ drilled 2 holes & used the plastic holders that came w/ the fan
^^ fan mounted in the cap, can't tell.... the shaft in the dizzy is cut down
^^ the mess of wires... believe it or not there's only 6 wires there...
^^ notice the dual ground....
^^ up close of the fans & you can kinda see the heat sink....
^^ put together
it's kinda strung up under the dash.... nothing too permanent yet... & i haven't cleaned the wires incase the ignitor goes again.... might as well make it as easy as possible next time
**oh ya.. forgot to mention... i also used a heatsink compound where the ignitor sits against the distributor to hopefully help a bit more (toyota didn't do that)
