88 FX 4A-C question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2004, 06:57 AM   #1 (permalink)
View donna's Photo Gallery
Question 88 FX 4A-C question.
there are three vacuum hoses going to the distributer , two on top one on bottom,,,i tried following the diagram in haynes manual on correct routing, but here lies the question,,, on one of the top hoses (drivers side hope this is correct too) there is a check valve, which way should air flow thru, ,,from metal lines or from dist vaccum ,,,,i can tell no difference in performance either way, but it has to do some function, so want it on correct. I replaced all the lines and like a dummy i did not mark them,,,
99 Solara
donna is offline   Reply With Quote
Old 03-05-2004, 05:51 AM   #2 (permalink)
I guess no one here has a sohc carbd 1.6, so is there a forum that does? thanks
99 Solara
Old 03-05-2004, 10:56 AM   #3 (permalink)
Banned
View |PuNiSh3R|'s Photo Gallery
donna, I'll get back to you in a little bit with the answer.
|PuNiSh3R| is offline   Reply With Quote
Old 03-06-2004, 05:05 PM   #4 (permalink)
View Dicipleofthelie's Photo Gallery
i have that engine in my 4 door
are you talking about those 3 or 4 little hoses?
that run around in front of the carb and over to the distributor?
current car: effed up AE-82 corolla
update: she spun a rod bearing... woooo
Dicipleofthelie is offline   Reply With Quote
Old 03-06-2004, 05:31 PM   #5 (permalink)
no, these three run from the metal lines to black hoses then to the vacuum advance on the bottom of distributer
99 Solara
Old 03-07-2004, 04:55 PM   #6 (permalink)
View Brown87Rolla's Photo Gallery
I had the same problem and pretty much guessed at it. There is a diagram underneath the hood of my car but the years have faded it away so I was struggling to make out where the hoses went.
Brown87Rolla is offline   Reply With Quote
