i need help badly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2004, 04:57 PM   #1 (permalink)
View GT_GREG's Photo Gallery
i need help badly
well ive tryed to finish my sr5 gts conversion... but ive not been able to get the car to start...
i know i f ahve a major electrcal issue but i dont know where to turn for help
if anyone out there knows about thecar a fair bit and thinks they can help please please call me at 416 676 6774..
im so frustrated right now by it that i dont knwo waht to do.
ive checked everything i can but nothing seems to work
416 676 6774 if anyone can help
GT
i go sideways faster than you can go strait....
GT_GREG is offline   Reply With Quote
Old 03-03-2004, 05:07 PM   #2 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
Sorry man, I'd be ringin' you if I knew an anwser!
Somebody help this dude out!
Good Luck Greg!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 03-03-2004, 05:09 PM   #3 (permalink)
to make things more clear
it seems i have a problem with grounds or power or something... this was a running engine and now i cant get it to turn over, spark or anything. but the fuelpump has power..
makes no sence to me at all
GT
Old 03-03-2004, 05:56 PM   #4 (permalink)
Operation Front Bumper
2advanced's Avatar
View 2advanced's Photo Gallery
So it doesnt turn at all? when i mean turn it doesn't even crank??
Are you sure all the fuses are in good shape?
2advanced is offline   Reply With Quote
Old 03-03-2004, 06:04 PM   #5 (permalink)
fuses are good.. relays are good.
GT
Old 03-03-2004, 06:18 PM   #6 (permalink)
2advanced's Avatar
when you did the sr5 to gts converstion what did you change?
engine, tranny? what?
was the car auto or manual ??
and what is it now??
Old 03-03-2004, 06:59 PM   #7 (permalink)
the car was a manual sr5.
the car is now a manual gts
i swapped
engine tranny harnesses
GT
Old 03-03-2004, 07:05 PM   #8 (permalink)
2advanced's Avatar
do you have power to turn on your head lights and radio etc?
or there is just no power at all?
make sure you have all your grounds connected to the engine block..
Old 03-03-2004, 07:06 PM   #9 (permalink)
yup the fuel pump works,headlights,turnsignals,4ways,evrything
they all work
GT
Old 03-03-2004, 07:12 PM   #10 (permalink)
2advanced's Avatar
did you check the main fuses at the battery located on the positive battery terminal
i believe there is a 30AMP fuse for the starter and ign system
Old 03-03-2004, 07:21 PM   #11 (permalink)
yea those are the fuseable links...
theyre both ok still
GT
Old 03-04-2004, 05:47 PM   #12 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
So did you also changed the ECU for the 4AGE?
-also check the Distributor, WIre, Ignition coil.
once i took the dizzy out, and wheni plugged in, it didn't start either, but noticed that i forgot to keep the #1 cylinder at Power position (not TDC).
look for simple stuff. had a friend who had his #1 spark plug damaged. luckily, 4AGE engine can start with out #1 cyl sparking.
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 03-04-2004, 09:30 PM   #13 (permalink)
2advanced's Avatar
but he can't even crank the engine.. the starter doesn't even work.. thats fucked up..
Old 03-05-2004, 08:06 AM   #14 (permalink)
all done guys...
it was the clutch start weith for the starter (i didnt think the year of gts for my swap had one)
and a coil ground
GT
