the PS on the 4a-f/e is on the intake side... the 4age's PS is on the exhaust side... so they're quite different..... you would have to pull the lines from a junker....
I have a smallport redtop 4a-ge from japan....
here are pictures before it went into the car:
http://www.cardomain.com/memberpage/219038/8
What i added or needed* and cost:
KBD header* $150
GTS thermostat housing* $20
MSD 8910 EIS tach adapter (kinda needed) $35
MSD 6AL/Blaster 2 coil (kinda needed, got used) $80
Spark plugs* $10
GTS radiator* (the lines are different, and since my 4a-fe had overheated i didn't want to take any chances so we went with a new one just in case) $150 shipped
New timing belt* $30
New alt belt* $15
Used 4a-ge flywheel* $40 (for your auto, i have a 4age flexplate)
Adjustable SARD fuel pressure regulator* (needed since i'm using 4a-fe ecu) $120
New oil filter* $5
New hoses* (vacuum, heater, radiator) $30 (roughly)
Distributor cap* (on my 2nd one, MSD has a hot spark
) $20 each
Longer throttle cable* $6 from a pull-apart
Exhaust work done* (this cost me a lot since i went with a full new exhaust... everything from the header back is new) $217 not including header
and if/when you need specifics of what i swapped over from the 4a-fe to the 4a-ge i'll let ya know.... if you need to know now and i'll try to help you out.... i can also send you the links from CC where i described in FULL detail the swap.... (each took me about 30 minutes to type up...)
performance gains: wow.... the first time i took it for a drive i was dissappointed about the steering... but i was all smiles when i got on it.... (it was loud cause the header didn't actually match up with the exhaust correctly)... i can redline it up to 7700rpm's daily and it's WAY smoother getting up there as well.... it's somewhat torqueless.. i'm not gonna lie (made a max of 95.7 ft/lb torque at the wheels).... but the curves of HP at the wheels is fairly impressive... ESPECIALLY since i'm running it off a tuned 4a-fe ecu...
bad picture, i know.. but:
....this was just a first dyno after 500 miles stock internally motor.... it's surprising how much quicker it is... and it will help me in auto-x... my car used to have bad understeering problems with the japanese gtz swaybar up front... but now i have the power to pull myself through....
check here for "completed" pictures... though not the most recent:
http://www.ac.wwu.edu/~milest2/motorswap/Done/
