Something is deathly wrong with my 4AGZE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2004, 10:08 PM   #1 (permalink)
View ericlee303's Photo Gallery
I was driving home today after getting some 94 gas when all of a sudden, the mofo starts knocking really loud! I'm like I don't believe this, it's broken!
I had a similar problem with my DA integra, but that turned out only to be a loose plug.
So I'm praying that maybe it will only be a plug. Removed the IC and checked the plugs. Shoot, plugs look good.
Next I check the gears, and it looks like the exhaust cam jumped a cog. Maybe the belt is old and worn, and got loose over time?
My question is, why the hell was it knocking loudly? I thought that 4AGs were non-interference engines?
Could the mis-detonation be pushing the valves the wrong way?
I'm totally not sure what kind of damage one cog would do.
But I do know that I'm severely pissed now, because I was really looking forward to driving it this summer.
Thanks for the help,
Eric
94 JDM 4AGZE Corolla powered by www.sdsefi.com
00 Yellow Integra Type R #795
ericlee303 is offline   Reply With Quote
Old 03-04-2004, 10:13 PM   #2 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
my 4age timing belt came loose once before and it does knock like a mofo...could be that the pulley-ish thing on the belt tensioner came loose-which is what happened to me.
either that or check for broken spark plugs...yes, they've broken on me before. but a large sign that points to a broken plug is the smell of unburnt gas...if u dont smell that then it's definately ur belt.
just simply line up the cam gears to the markings on the plate and let us know the news.
-edit-
i didnt realise that ur cam gear is only off by 1 cog..that's not causing the prob then. i too had my cam gear off the proper timing once and the motor just had no power and sounded super loud at higher rpm's. i didnt get any knocking.
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 03-04-2004, 10:56 PM   #3 (permalink)
aka TRD_roLLa on CC.com
View ractive_roLLa's Photo Gallery
ahhhhh no way... i've yet to meet the sc beast =(
fix it!!!
ractive_roLLa is offline   Reply With Quote
Old 03-05-2004, 04:46 PM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
NO!!!!!!!!!!!!!!!!!!
I hope things work out. I still have to line up with you and settle once and for all
FYI- http://forum.toyotanation.com/showth...ighlight=4agze
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 03-05-2004, 05:13 PM   #5 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
What kind of knock.
In sync with one cylinder or something more or less repetative?
In any case I would do a compression & leakdown test. To make sure a piston isn't broken.
I'm thinking you'll end up pulling the oil pan and replacing some con rod big end bearing and bolts.
Just a guess though.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
