#2 Spark plug is black all others are fine. Is it the rings or valve stem seals? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2004, 05:50 PM   #1 (permalink)
View Brown87Rolla's Photo Gallery
I was going to do a compresion check but after I get a reading across the cylinders how do I know if it is the Valve stem seals or Piston rings that are leaking? It is only the #2 plug that gets black every two weeks, all others are normal color ( brownish tan ). When I start the car in the mornings it definetly blows blue exhaust.
Brown87Rolla is offline   Reply With Quote
Old 03-07-2004, 09:01 PM   #2 (permalink)
View reym's Photo Gallery
Oh my goodness, if the compression is normal then you are looking at a valve guide leak. Try using a STOP or STP oil additive and replace your plugs with a hotter one, that migh temporarily solve your problem.
reym is offline   Reply With Quote
Old 03-07-2004, 10:31 PM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
check the resistance in that wire and consider getting a hotter plug, if you're getting weak spark it'll look like ou're running rich
-Nick
Nick is offline   Reply With Quote
Old 11-03-2006, 08:09 PM   #4 (permalink)
schn0354's Avatar
View schn0354's Photo Gallery
If you get good compression, it is most likely a valve stem seal leak. However, your oil control rings can be worn causing oil consumption while still getting good compression. This was true in my case. I just replaced valve seals and rings, but the wear on my engine was even across each cylinder. In your case, you may have a cracked valve stem seal for just cylinder 2. Do you hear any odd valve train noise? I would only install recommended plugs.
schn0354 is offline   Reply With Quote
