2003 Corolla CE Routine Maintenance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2004, 05:13 PM   #1 (permalink)
View burnt03's Photo Gallery
Creeping up on 30,000km so it's just about time to start in with some of the maintenance. Looked through the manual and got all the information that I could out of it, but was wondering about a couple other things.
- How often are you supposed to change the brake fluid?
- How often do you change the fuel filter? Where is it located?
- Where is the "air conditioner interior dust and pollen filter" located?
- Do any of you run that fuel system/fuel injector cleaner through the system?
- Is there anything else not mentioned in the manual that I should worry about?
Thanks a lot
1990 Corolla SR5 (Mine)
2003 Corolla CE (Wife's)
burnt03 is offline   Reply With Quote
Old 03-14-2004, 06:18 PM   #2 (permalink)
View hooolala's Photo Gallery
Re: 2003 Corolla CE Routine Maintenance
i never change the brake fluid, all i do is add more if is low.
Fuel filter? no idea where that is, but i do know you might need to change your transmission filter, just check to see if your transmission fluid is brown or red, if is brown, you need to change it
behind the glove compartment, right above the ECU
yes, every 10,000 miles, it's not required, i just like my car to run clean
i don't know whats in the manual but i do know you might need to change your spark plugs and air filter
04 Supercharged Corolla (automatic)
R.I.P 98 Corolla LE
hooolala is offline   Reply With Quote
