Fuel pump requirements for 5psi boost (carb'd 4a-c)? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2004, 08:24 PM   #1 (permalink)
üb3r g33k
O 16581 72452 5's Avatar
View O 16581 72452 5's Photo Gallery
As many of you have seen by my other post, i'm planning on a blow-through set-up for my 4a-c using what i thought was an Eclipse turbo, i come to find is a Starion turbo. Reguardless, i will be using this turbo, i'm wanting to know what i need to look for as far as a fuel pump. I'm sure the stock one won't be able to keep up, so i was considering perhaps an external fuel pump from a 305 (carb'd) Camaro.
Where is the fuel pump located on my SR5?
http://www.mazdaperformance.net
http://www.midwestrx7club.com
O 16581 72452 5 is offline   Reply With Quote
Old 03-17-2004, 01:24 AM   #2 (permalink)
Banned
View |PuNiSh3R|'s Photo Gallery
It is mechanical.. and it would be located right on the engine.. driven by the camshaft.. You will want to remove it.. cut out a 1/4 thick block of aluminum or whatever metal you choose to cap off the hole.. Install a 4-7PSI external pump.. some where in the 35GPH range.. and install it right next to the gas tank so the tank basically gravity feeds right into the pump.. You will then want to put a return line .. a T in the gas line at the closest spot to the fuel in on the carb float bowl.. that will relieve you of any air that will form in the lines.. causing an otherwising troubling vapor lock in the line. You can then use a relay connected to the oil pressure switch on the block to trigger the pump when the oil pressure rises.. After that you will want to kick yourself in the ass for wasting your time and money on a single cam'd 4ac, specially one with a lot of miles on it and the fact that you will probably blow a compression ring or a valve seal.
|PuNiSh3R| is offline   Reply With Quote
Old 03-17-2004, 01:45 AM   #3 (permalink)
üb3r g33k
I love the encouragement you're giving me with this project.
Old 03-17-2004, 02:13 AM   #4 (permalink)
Banned
Just keepin it real my wigga
Old 03-17-2004, 12:00 PM   #5 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Punisher:
Chris Corolla S is offline   Reply With Quote
