ac switch problem
a week ago my heater stopped working and after taking apart pretty much all my dash I found out that my switch for the fan speed is burned up slightly.
I replaced the switch and soddered in a new plug. I tested the only red wire there was and found that i could get nothing from it. There is a light attached to the switch taht lights up the display when the lights are on so i know it is the switch that is the problem not the blower. so what next should i try to do to fix this?
i have also replaced the relay and break, checked all fuses. The fuse for the AC system is on the right hand side "kick panel" right?
it is a 88 DX sedan.
