60k mile svc? help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2004, 12:04 PM   #1 (permalink)
View jjcnsx's Photo Gallery
60k mile svc? help
Hi all,
i recently purchased a 99 LE automatic w/ 53k miles
i am planning to do 60k miles svc. but, i am not sure exactly what to do.. please help
to the best of my knowledge i need to do these:
- motor oil & filter
- air filter
- ATF fluid
- coolant
- sparkplugs
- PCV valve
how about timing belts and (serpentine belts), water pump and thermo stat?
also, do i need to replace these:
- differential fluid (do we even have this? For a front wheel drive?)
- cap & rotor
- sparkplug wires
- in cabin airfilter (do we have this)?
thank you in advance to help.
-jjc.
jjcnsx is offline   Reply With Quote
Old 03-24-2004, 03:05 PM   #2 (permalink)
View Nico's Photo Gallery
Re: 60k mile svc? help
Originally posted by jjcnsx
Hi all,
- air filter
- ATF fluid
- coolant
- sparkplugs
- PCV valve
-jjc.
Just change oil + filter, sparkplugs and air filter (if too dirty)
- cap & rotor
- sparkplug wires
-jjc.
No need to change any of these at this stage except if your engine runs poorly or if you have any problem with them.
What I would however consider doing is changing the timing belt, THAT IS REALLY NECESSARY, check a/c charge, check brakes condition (front and rear) and check all fluid levels.
Nico
Nico is offline   Reply With Quote
Old 03-25-2004, 05:18 PM   #3 (permalink)
ATF fluid
What kind of ATF Fluid should i use?
Toyota OEM? or any ATF?
any spec that i need to use? i dont have the user manual.. is there a link i can look up? 99 corolla
-jjc.
Old 03-25-2004, 06:45 PM   #4 (permalink)
RedAE102's Avatar
View RedAE102's Photo Gallery
Any Dexron III certified ATF will meet Toyota's requirements, but synthetics perform better.
Though most of us (me included) should change our timing belt every 60,000 miles, it would be quite impossible for you to do, as your engine uses a timing chain and not a belt.
'93 Corolla AE102 XLi saloon
We're all looking for something.... Something to be...
RedAE102 is offline   Reply With Quote
Old 03-25-2004, 06:54 PM   #5 (permalink)
Please educate me.. how would synthetic ATF perform better? can you tell the difference?
also, my 99 corolla uses timing chain??? woow. i didnt know that
-jjc.
