differential whining loudly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2004, 09:40 PM   #1 (permalink)
Dis reg!
AEugene86's Avatar
View AEugene86's Photo Gallery
it started last night on the way home from the KC meet, (which was a good meet ) anyways so now diff is very loud, ear piercing loud at times. what would be causing this?
'87 Corolla GT-S HB
AEugene86 is offline   Reply With Quote
Old 03-28-2004, 10:49 PM   #2 (permalink)
Doh!
View sagaboy77's Photo Gallery
i have the exact problem with mine i was told the fluid is prob low, prob gonna get teh fluid flushed in the nex week or so and see if it helps.
**sig in violation of rules - no animations**
sagaboy77 is offline   Reply With Quote
Old 04-02-2004, 09:24 PM   #3 (permalink)
Shit Disturber
View hopeful's Photo Gallery
if it happens while taking turns, say bye bye rear end... the gears are out of spec and basically have just worn down. Shit happens.
There is no purpose to a life which does not search out its purpose, look for god and you shall find Him. Know what you feel of the oneness of god within you is no coincidence, and know that no coincidence is without purpose.
hopeful is offline   Reply With Quote
Old 04-02-2004, 09:32 PM   #4 (permalink)
operation boro thunder
View project trueno's Photo Gallery
^like the guy said, if its during turns, then the diff. pinion gears are probably out of spec or simply worn. Or even damaged....
if this is happening even going straight ahead, my guess is incorrect drive pinion and ring gear meshing, did you or a shop do any rear end related work to the car?
Of course check if there is enough diff oil first, and hope its the right kind
project trueno is offline   Reply With Quote
Old 04-04-2004, 02:52 PM   #5 (permalink)
Dis reg!
AEugene86's Avatar
yeah, I already changed the diff oil, it was low, which is probably why I'm having this problem. The car has been making this noise since I got it but now its worse. It does it always. even on straight aways. I found a piece of metal sitting on top of the drain bolt (along with sludge) kinda a looks like a small, hollow, hershey kiss. could it be a bearing? or should I just get LSD.
'87 Corolla GT-S HB
Old 04-04-2004, 07:03 PM   #6 (permalink)
Operation Front Bumper
2advanced's Avatar
View 2advanced's Photo Gallery
this sounds fun, feels like transmissions class LOL..
well if its happening while going straight as well it could be pinion bearings or the side bearings in the diff that hold the drive shafts...
thats my two cents
2advanced is offline   Reply With Quote
