How to change brake pads in 90 corolla? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2004, 10:36 PM   #1 (permalink)
View 99FBPSi's Photo Gallery
Hi, I have a 1990 Corolla DX and I want to change the front brake pads. How do I do that? Also which pads should I use for just daily driving.
99 Honda Civic Si
99FBPSi is offline   Reply With Quote
Old 04-04-2004, 11:49 PM   #2 (permalink)
View ORACLE's Photo Gallery
If you're pretty good with tools, it's a fairly simple job. Frankly, If you're new to working on cars, or don't know very much about them, it might be a good idea to go to midas, etc.
-First thing to do is loosen the wheels (Not all the way, but just a turn). You never want to torque anything while a car is on jacks.
-Under the hood, loosen the cap fro the brake fluid. Don't take it off since you don't want dirt getting in there.
-Lift the end of the car you're working on. Choc the wheels on the oposite end. If you're working on the fron left, choc the right rear wheel. A brick does the trick.
-Take off the wheel
-There are two bolts (They might be a hex head) on the top & bottom of a caliper. Loosen them & take em out.
-Take off the caliper by lifting it out.
-You can now pull out the pads. Look at whick pad goes on which end.
-Take one end of the old pad, put it against the brake piston & use a C-clamp to push the piston back into the caliper.
-Install the new pads. Use that anti squeeling grease they give you on the back of the pads. (Don't get any on the part that wears away).
-Now would be a very good time to replace the discs if they are pitted, warped, thin, cracked, etc.
-Push the caliper back on the disc.
-Put some anti-seize on the caliper bolts & screw 'em in.
-Make sure everything is back together properly & turn the hub to see if it spins.
-Put wheel back on, screw the nuts back on all the way, don't torque 'em just yet.
-Bring the car down & then torque the wheels.
-Close the brake resevoir.
It should be as simple as that, remember to test the brakes before you drive anywhere.
As for brake pad type, anything is fine for normal driving. Organic pads are cheaper, but wear out faster, but I would recommend carbon metalic, they're safer & last longer.
-1991 Corolla GT-S
-1994 Ford SHO MTX
ORACLE is offline   Reply With Quote
Old 04-05-2004, 10:29 AM   #3 (permalink)
I think I might need to change the fluid also. So how can I bleed the fluid? And is there a certain pattern I should use to bleed them?
99 Honda Civic Si
Old 04-05-2004, 07:59 PM   #4 (permalink)
TTT
99 Honda Civic Si
Old 04-05-2004, 08:37 PM   #5 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Go to the auto parts store and get yourself a Haynes manual for step-by-step instructions. For instructions on Bleeding brakes on an AE-92, go here: http://geocities.com/nuahs_cx/
BTW you only have to remove the bottom bolt on the caliper then just pivot it up off the rotor and suspend it from your spring with some wire or a rag or something.
Chris Corolla S is offline   Reply With Quote
Old 04-06-2004, 01:05 AM   #6 (permalink)
OK, thanks. The procedure is the same as my civic.
99 Honda Civic Si
Old 04-07-2004, 11:29 AM   #7 (permalink)
That way works as well, but it's still a good idea to remove the second caliper bolt to dab some anti seize on. That's definetely one thing that you don't want to have problems getting off.
Good advice to suspend the caliper saving your brake hoses.
-1991 Corolla GT-S
-1994 Ford SHO MTX
Old 04-09-2004, 10:43 PM   #8 (permalink)
Is there any kind of procedure I need to do to fill the fluid? I poured the fluid in and the brakes still dont work? Its very loose.
99 Honda Civic Si
Old 04-10-2004, 12:23 AM   #9 (permalink)
If you bled the brakes properly, there should not be a low pedal feeling. Is the pedal spongy, or low? Describe "Loose".
Brakes are not something that you'd want to fool around with. It might be easier to get the car towed to a Midas.
Did you watch the level in the brake fluid resevoir while you were bleeding it? Don't let it get low, because you'll just get more air in the system. Try bleeding all four wheels again.
-1991 Corolla GT-S
-1994 Ford SHO MTX
Old 04-11-2004, 01:50 PM   #10 (permalink)
Ok I fixed the problem. I bled some of the new fluid through so it will get in the lines.
99 Honda Civic Si
Old 04-12-2004, 06:50 PM   #11 (permalink)
Banned
View |PuNiSh3R|'s Photo Gallery
I've done some research and came up with the conclusion that you can't change the brake pads. Have a good day.
|PuNiSh3R| is offline   Reply With Quote
Old 04-13-2004, 11:23 AM   #12 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
oOoOo spanks fer the plug.
anywho...to change pads it's the same as your si, or any other car for that matter.
i have a write up on my site...here's the link http://geocities.com/nuahs_cx/maint.html
it's in the middle of the page with pix to guide u through it
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
