Yea, like what Gim said...
The '86-87 injectors are rated for a 182cc at 1 OHM, while the '88 to '89 are also rated at 182cc but at 2 OHMS.The '90 to 91 are 235cc's at 2 OHMS. The 5 V/pc versions are bigger yet at a rate of 295cc also at 2 OHMS.
Unless you have, or plan on bigger mods and have a way to alter the computer, I'd stick with the stock injectors.
If you're thinking of getting an adjustible fuel pressure regulator to play around with the pressure, I don't know as of yet how Toyota's computer will react to it. When I had my Fords & my GM's, the computer (If it's not programmed for the added pressure) would compensate by telling the injector to flow less fuel, thus defeating the purpose. It only remained at the altered pressure at WOT, in wich the engine already runs rich, so there's no point. Basically, you'll get more of an affect by just unplugging & plugging the vacuum hose for FPR.
-1991 Corolla GT-S
-1994 Ford SHO MTX
