cheap swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2004, 03:58 PM   #1 (permalink)
View Morpheus's Photo Gallery
cheap swap
http://www.nippon-motors.com/Toyota%...%20Special.htm
I wonder how hard it would be to put that in a corolla like mine. 88 DX Sedan.
cheap 15hp and its fuel injected.
Morpheus is offline   Reply With Quote
Old 04-18-2004, 04:08 PM   #2 (permalink)
Danno
View 89yotarollagts's Photo Gallery
cheap is right you should be able to put that in not positive tho i dont know my stuff like most guys on here
89corollagts
69gtojudge
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 04-18-2004, 07:46 PM   #3 (permalink)
anybody?
Old 04-19-2004, 10:00 AM   #4 (permalink)
Official Acura Troll
View 02RSX90camry's Photo Gallery
should be extremely easy, but does it come with an ECU? switchin from carb to efi might be a bit of a bitch, but shoudl be pretty damn easy other than that. juts make usre u get an ecu and whatever wires u need to do the switch.
02RSX90camry is offline   Reply With Quote
Old 04-19-2004, 02:57 PM   #5 (permalink)
Gameroom cash: $121755
isn't worth it...... the 5a-fe makes about the same horsepower as a carb'd 4a-f....... just the fact that it has a 5 in front means that it went into production after the 4a-fe and before the 7a-fe....
1) 1990 Corolla "SR5", part silvia, 7age.... & more 2) 1986 MR2, "MK1.22" 91 5SFE/S54 swap 3) 2010 Corolla S 5-speed (the super nice/low mileage DD - wife) 4) 1998 Camry (the boring, high mileage DD - me)
Old 04-19-2004, 05:31 PM   #6 (permalink)
Danno
id put a 4age red top in their
Old 04-19-2004, 07:00 PM   #7 (permalink)
15 hp for $200.
How isn't it worth it?
Old 04-20-2004, 03:04 PM   #8 (permalink)
15hp... where'd you get that number from? lol
a 4a-f will put out about 90-95hp at the flywheel, a 4a-fe will put about 102-105hp at the flywheel (all at new, stock specs)
a 5a-fe puts out about 90hp at the flywheel.....
Old 04-20-2004, 03:33 PM   #9 (permalink)
SR5 Rolla's Avatar
View SR5 Rolla's Photo Gallery
lol...so why would pun put one in his car? Engine blown? If it's rated at 90hp?...Why would he have gotten rid of his 4af? He use to preach 4AF. I guess he wanted efi???? ***oops Pun said he was using a 7afe..what's that engine rated at?
Bubb Rubb: "When you wanna WOOO WOOO!!! It's that Woooo WOOOO!!!" "That's only in the mornin'. You 'posed to be up cooking breakfast for somebody and so... That's like an alarm clock! Whooooo!!!"
SR5 Rolla is offline   Reply With Quote
Old 04-20-2004, 04:04 PM   #10 (permalink)
7afe changed a ton during different yrs. in 93, it was way up at 115hp, 110? ft-lb. by 95, it was at 110hp, 105 ft-lbs, 96 due to tougher OBDII, it was around 105hp, and up to 115? ft-lbs.
that's for the corolla versions, i think there were certain Celi ST that had 7afe in them, not sure on their ratings though
Old 04-20-2004, 09:04 PM   #11 (permalink)
celica's had the same output.... i think the highest from stock a 7a-fe got was 112hp
